Hello to the community.
I use Denon Engine sometimes, this is a pretty good piece of software in many aspect.
The big lack is about the Vdj library integration i must do this manipulation.
Traktor and vdj share the same .M3u format.
The minor difference:
-Traktor is : UTF-8
-Vdj is UTF-8 With BOM
...I must to modify to be visible for Traktor to be visible for Engine Dj. :(
Does Atomix devs are in contact with the devs of DenonDj in any way about a full native integration in Denon Engine Dj?
Best regards, Fab.
-Traktor is : UTF-8
Best regards, Fab.
Posted Fri 06 May 22 @ 3:19 pm
