Topic: Help removing Vocals and instrumental out of a song
I am having trouble removing instrumental and vocals from a song i keep clicking on detune and clicking vocals my layout is on pro and it wont work can anyone help please.
Posted Sun 13 Mar 22 @ 8:30 pm
detune is a looping plugin
I have tried updating detune however it says unable to write the update then when I try again it says download failed
What locodog is saying is that detune is not for removing anything. It's a looping effect
You should be on for instance the stems padpage and using the pads to remove parts/stems
... and of course first make sure the stems separation is enabled on your setup, and has been run either automatically or manually on the track
Use the built in stems feature ;-)
