Topic: Couple of questions
1) How do you name a saved loop pad? Currently the pad shows what time in the track the loop is activated
2) How do you change the bpm counter to show one decimal, for example 128.1
Thanks
Posted Fri 04 Mar 22 @ 2:05 am
1 is setting, savedLoopDisplay, you can set the name in the poi editor.
2 requires a skin edit.
Where exactly is the savedloop setting? When I right click on the saved loop pad it opens the poi editor. Name 'loop intro', type 'Saved Loop' , cue 'marker only'. Clicked X on top right of poi editor. Still no change in the saved loop pad. Still shows time the loop is activated
in options & tweaks
Where exactly in the options and tweaks is the setting?
search for it.
How do you change the bpm counter to show one decimal point? What is the text that should go in the xml skin?
search for
"%Pbpmex"
change to
"%Pbpm"
in default pro there are 4 instances.
Great, thanks
