I have tried almost all the listed automix options and the closest to what I like is FADE (remove silence) with a length setting of 0sec, but some songs will still clip before the song actually ends. What I am trying to achieve is a song playing to the very end of the audio then starting the next song. Any suggestions?
Posted Tue 01 Mar 22 @ 11:00 pm
I have had the same issue for years.
Best way round it is use fade (remove silence) then set the mix full start and mix full exit points manually in the POI editor.
I've raised various posts about this over the years with no solution. The radio mode (fade out, cut in) what should cover this but it doesn't work properly.
Posted Wed 02 Mar 22 @ 7:59 am
I'd like to try your settings but what is the POI editor? My solution has been to monitor my feed and then use the spacebar to begin the next song when appropriate. Clearly this is time consuming and prevents me from interacting with my audience. I have thought that perhaps a variable delay of 0.5 to 1 sec can be built-in so the next song isn't immediately on top of the previous song's ending.
Posted Wed 02 Mar 22 @ 6:06 pm
Maybe:
Use fade, skip silence, and set the fade time to 2 seconds gap.
Maybe more:
https://virtualdj.com/forums/235013/Wishes_and_new_features/OPTIONEN____automixMode____fadelengh__VDJ_SKIPT.html
Maybe more:
Posted Wed 02 Mar 22 @ 7:44 pm
Right click on a track the select POI editor.
Posted Wed 02 Mar 22 @ 9:42 pm
POI is an acronym for Point Of Interest. Open up the user manual, pres "Ctrl + F" and you can search by word. POI should come up in your search.
Posted Wed 02 Mar 22 @ 9:46 pm
OK, I found the POI editor in the user manual. I'll have to get a big bottle of wine and start experimenting. Thanks guys!
Posted Thu 03 Mar 22 @ 1:21 am
