How do you create the shortcut after downloading?
Posted Mon 30 Aug 21 @ 3:34 pm
Should automatically create a shortcut on the desktop unless you told it not to.
You can try a "repair" install to see if it is created, or just find the .exe in program files and create a shotcut and drag to the desktop.
Posted Mon 30 Aug 21 @ 3:37 pm
