The standard 2021 64 won't run on the 64 bit ARM processor.
The Workaround was to upgrade to WIN 11. This uses the 64 bit emulator BUT when it computes the Stems the processor is flat out 99% and eventually crashes the machine even when the process is set to idle.
The 32 bit 2020 run the processor at 15% but without stems
My question..... is there any plans for VDJ run natively on 64bit ARM??
My Workaround may help someone with pain better PC???
Posted Mon 23 Aug 21 @ 9:29 pm
