Hello everyone,
I have been using Virtual DJ software at home for fun. Today I have realized that right channel sound quality is not as good as the left channel. Right channel sounds deeper and lacks low frequincies.
I would appreciate if you could help me solving this issue.
Kind regards,
Software is installed on my Lenovo Carbon X1 with Win 10 installed.
Kind regards,
Posted Sat 21 Aug 21 @ 5:18 am
Very unlikely to be a vdj issue, more likely to be an issue external to vdj, something in your signal chain, a defective audio jack, something wrong in your amp or speaker.
Easiest test is to play music from, windows media or vlc or whatever program, if in that case a audio problems is detected, then we can rule out a vdj issue.
Posted Sat 21 Aug 21 @ 7:29 am
To be honest I don't use any controller or external device. It is just my computer and the software.
I have just realized that deck2 (this is what I meant originally) bass/lower is like silenced. I am not sure how but, it is what it is. As a temporary solution, I have switched to 4 decks and started using decks other than 2 or B.
UNfortunately the issue still exists.
Posted Sat 21 Aug 21 @ 10:07 am
So your saying the issue is any deck excluding A (deck 1)?
Posted Sat 21 Aug 21 @ 11:58 am
