Trying to make a script to mix now and reset pitch. This one works only going from lower BPM to higher. mix_now&pitch_reset 1%
I have done a few other variations but no luck.
Any ideas?
Any ideas?
Posted Thu 12 Aug 21 @ 8:01 pm
Trying on a button present on both sides of some controller, or a global one (keyboard) ?
You want the other deck to reset Pitch once mix is done ?
Try ..
You need to wait for mix to be almost completed, thus the "delay" with repeat, in order the other deck to become "active"
Try ..
mix_now & repeat_start '$endmix' 3000ms & repeat_stop '$endmix' & deck active pitch_reset
Posted Thu 12 Aug 21 @ 8:36 pm
That works. Just need to slow cross fader a tad.
Thanks
Thanks
Posted Fri 13 Aug 21 @ 1:52 pm
