I want to map the LED on the "PANEL_SELECT" button on the DDJ-SZ2 to light up if the eq mode is set to "ModernEQ" but i cant find the LED_PANEL_SELECT on the factory mapping.
is possible to add it on the XML ?
Posted Fri 11 Jun 21 @ 4:41 pm
          There is no LED for this button available as Midi Out (not offered in firmware)
    Posted Fri 11 Jun 21 @ 6:12 pm
Thanks! :)
Posted Thu 17 Jun 21 @ 7:15 pm
