After one of the latest upgrades (where the stems fxbutton is introduced) the vocal button for stems on deck 2 doesn't work, but it does work on deck1. I tried to reinstall with a downloaded latest version however without any success. I tried with and without my controller, the result is the same. If there is a way I can adjust this please let me know
thanks in advance
Jan
thanks in advance
Jan
Posted Mon 24 May 21 @ 6:12 am
there were issue in EA but was fixed in release
colorfx vocal, stem vocal from EQ, Vocal button from pads, stemfx over vocal tested with echo
tested all again here, no problem
Make sure stems are computed for the track (can test with the same track right & left)
maybe reset some setting -> Controls ?
stemsBleedMuteVocal
stemsBleedOnlyVocal
stemsBleedMuteInstru
stemsBleedOnlyInstru
setting try automation -> resetStemsOnLoad
stemsBleedMuteVocal
stemsBleedOnlyVocal
Posted Mon 24 May 21 @ 7:35 am
