Which external USB soundcard would you advice currently on the market with VDJ Pro? I used Numark DJIO before but sound is distorted, have reinstalled drivers several time so likely the soundcard is malfunctioning. Numark doesnt appear to sell this soundcard anymore.
Any advice?
Any advice?
Posted Sun 23 May 21 @ 2:06 pm
Could just be you need a higher buffer on the driver.
If using asio, try 256 or 512 samples...
But if broken, pretty much any sound card works with VirtualDJ.
1000s of them, a few here : https://virtualdj.com/products/hardware.html?category=soundcard
(but the one in the link are a bit biased against those using external sound card for DVS inputS)
Posted Sun 23 May 21 @ 2:39 pm
Depends on your budget and the in/out channels you want.
The most popular ones are the AUDIO 2, 6 etc from Native Instruments and the Scarlett series from Focusrite.
Posted Sun 23 May 21 @ 6:28 pm
