Hello ive own a DDJ-1000srt for 3 months now an have been enjoying it. BUT. im preparing for a zoom party and i cant get the output heard on Zoom. When i pug in the old DDJ-SB3 it works fine
Zoom Audio = Speaker is set toDDJ-100srt
Posted Fri 21 May 21 @ 3:32 pm
DDJ-1000SRT is not using a "Master + Headphones" audio setup where you could "capture" the master output audio bus.
It uses an external mixer audio setup where the audio of each deck is sent on the mixer of 1000SRT and the mixing is done by the controller on hardware level.
Therefore it's impossible to "capture" the "master output" of 1000SRT
The easiest solution for your case would be to run an audio cable from "booth" output of the controller back to an audio input of your computer's built in sound interface, and use that input on Zoom.
Posted Sun 23 May 21 @ 9:37 am
