Topic: Audio quality "fades away"
I have been using VDJ for a while now with no issues. I was notified of a new version and upgraded last night. Now when I start a song it sounds okay, but slowly (over a few minutes) the sound quality deteriorates until is is too poor to listen to. As the quality falls it sounds like there are effects (like a flanger and reverb) being added before the bass falls out and the sound gets too "thin" to continue. Any suggestions to fix this?
Posted Sat 15 May 21 @ 10:43 pm
Could be the audio buffer on the sound card running dry.. . (if it sounds distorted etc)
Depending on what hardware/soundcard you have try set the buffer to 256 or 512 (samples).
You can do this directly on the ASIO driver (if using that) or inside VirtualDJ settings, look for latency and try value from above
If on Windows you can also use this tool to see if anything prevents real time audio:
https://www.resplendence.com/latencymon
