I'm looking to start a twitch for my sets. The last topic I found on this was 10 years ago, so I figured the hardware's a lil better these days :D
I ideally would have my computers webacm for my DJ controller, phone camera (or other) for my personage, and then a 3rd camera to the audience. I looked into getting a gopro but apparently it doesn't integrate into the native software. Or does it?
I have a DSLR, but that seems like overkill.
Would love a good camera with tilt, pan, and zoom features that can be seemlessly integrated into VDJ livestream features. Recs welcome!
Posted Wed 07 Apr 21 @ 6:20 am
DLSR is never overkill, use the best application or hardware to get the best out of it !
Posted Wed 07 Apr 21 @ 11:28 am
I use a simple Canon M200.
Posted Wed 07 Apr 21 @ 11:54 am
Can i use a PS3 eye cam for a livestream?
Posted Wed 07 Apr 21 @ 12:04 pm
And thats a really great cam instead of a webcam :)
Posted Wed 07 Apr 21 @ 1:32 pm
Yeah I usually use my DSLR for photographing the event. But do you need obs or can the DSLR be played natively through VDJ?
Posted Fri 09 Apr 21 @ 5:19 pm
plug it in and try it.
Posted Fri 09 Apr 21 @ 6:13 pm
I use Obs with my Canon 7D, through EOS Webcam Utility
Posted Sat 10 Apr 21 @ 6:09 am
I feel a total novice compared to all of you on here I am currently using a repurposed Xbox 360 camera . In my defence Ive concentrated on upgrading my controller and computer . What camera would you recommend for a very tight budget a max of say £40 ?
Posted Sat 10 Apr 21 @ 2:47 pm
IMO if you're only prepared to spend £40 then you may as well not bother.
Yes you can buy a webcam for that, but it won't be very good.
The one I use (Logitech C922) costs double that, and it's just OK. It gives a reasonable image but nowhere near what you'd get from a DSLR or similar.
Posted Sat 10 Apr 21 @ 3:17 pm
A photographer told me something recently that I hadn't thought about:
Unless you are an enthusiast the best camera you own will be the one in your phone. It's probably less than 3 years old tech, and you have probably paid a couple of hundred dollars for the camera alone, since that is usually the most improved part in new phones
... so unless you are in the $500+ webcam marked, that may be something to think about. I know I did
Posted Sat 10 Apr 21 @ 4:07 pm
And if you're streaming from home, you can control or spend a little bit of money on improving lighting, which will make a huge difference and make mid-range camera's pretty decent.
Posted Sat 10 Apr 21 @ 5:38 pm
Cheers guys didn't think about using my phone , Ive got a pretty good L.E.D. lighting system . The reason for ultra tight budget is i am disabled ( I do not need my legs to dj ) without gigs and parties money is super tight . Not because I am a cheapskate.
Posted Sun 11 Apr 21 @ 1:31 am
I've tried to go through EOS utility directly to Virtual DJ. Is this possible? If so, is OBS just more optimal for editing feeds?
Posted Tue 13 Apr 21 @ 10:05 pm
Just like you said, its easier to edit etc..
Posted Wed 14 Apr 21 @ 2:04 pm
