Hi can anyone help.. is there a option to use stems on 1 deck and use the high low and miss on deck 2 instead of either both decks being the same.. example
Deck one I use vocal out and on deck 2 I can filter out the low mids and highs..
Thanks
Thanks
Posted Mon 15 Mar 21 @ 4:40 pm
Not currently....
But can always use filter as audio fx on deck 2 instead.
Or vice versa, use stems as audio fx on deck 1
Posted Mon 15 Mar 21 @ 6:58 pm
