Hello,
Will vdj2021 works the same on a MacBook Pro M1 and a MacBook Air M1 ?
Any risk of heating on the Air for session of 4-5hrs ?
I only play MP3 (with stems already précomptée) stored on the ssd disk. No video.
Is the Air enough for this use ?
Thanks
Thanks
Posted Tue 02 Mar 21 @ 6:03 pm
Air will be completely fine.
Posted Tue 02 Mar 21 @ 6:15 pm
I will use it with a Pioneer DDJ1000. If this could be useful...
Posted Tue 02 Mar 21 @ 6:30 pm
DDJ-1000 now has drivers for M1, so that part should be fine
https://www.pioneerdj.com/en/landing/support-for-macos-big-sur/
As for Pro vs Air, touch choice... but for the usage you mention, the Air should have no problem with that. And performance differences between Air / Pro is said to be a lot less now with the M1.
A nice article here that might be of interest:
https://www.businessinsider.com/apple-macbook-air-m1-vs-macbook-pro-m1?r=US&IR=T#-the-bottom-line
Posted Tue 02 Mar 21 @ 7:31 pm
