Buongiorno a tutti...
premesso che non sono capace di mappare la mia console Pioneer DDJ 1000 SRT, potete dirmi dove posso trovare/acquistare una skin per poterla utilizzare con la nuova versione 2021?
Grazie
Grazie
Posted Fri 26 Feb 21 @ 10:16 am
It's natively supported - so it works out of the box
But it looks like your license may be a problem, because you are listed as having an LE (limited edition) license - probably from another controller
But if you get the pro license, the DDJ-1000 SRT should just work - no extra mapping or skin needed
You can sign up for the PRO subscription which is $19 per month - then you have a full month to test it with your DDJ-1000 SRT
Posted Fri 26 Feb 21 @ 12:35 pm
la console è supportata plug & play da Virtualòdj 2021 per cui basta installare i drivers e collegarla al pc per poterla utilizzare.
https://www.virtualdj.com/manuals/hardware/pioneer/ddj1000srt.html
Posted Fri 26 Feb 21 @ 5:22 pm
Grazie.
Posted Mon 01 Mar 21 @ 2:00 pm
Grazie.
Posted Mon 01 Mar 21 @ 2:01 pm
