I'm having trouble setting my headphone mix and external speakers. I external speakers play but I'm unable to preview my upcoming track with my headphones. What configuration should I use? My output is speaker+ headphones, hardware settings I'm not sure about. Also what should the settings be on the drop boxes for master, booth & headphones be set at? the output be set to? I'm sending up flares for help!!!
Posted Sun 21 Feb 21 @ 8:39 pm
without base infos not much help :\
OS ? sound board ? controller ? available audio inputs/outputs ...
Give a screenshot of current audio settings it always helps
Posted Sun 21 Feb 21 @ 8:49 pm
Make sure you have setup the sound correctly for your controller.
https://virtualdj.com/manuals/hardware/numark/nvii/setup.html
And use the channel "Cue" (headphone) button to select what to hear in headphones.
Keep in mind most controllers also have a headphone volume knob, as well as headphone mix knob (blend between listening to cue channel and master)
Posted Sun 21 Feb 21 @ 9:04 pm
