I have a new Denon prime 4, do I have to load the Denon engine if I'm using VDJ?
Posted Tue 09 Feb 21 @ 1:31 am
Here is the VDJ hardware manual for it
You basically only need to do what it says in the setup section
https://virtualdj.com/manuals/hardware/denon/prime4.html
Posted Tue 09 Feb 21 @ 2:03 am
The Prime 4 works really well with VDJ. I have been using this setup to stream on Twitch regularly.
Engine Prime is Denon's librarian software, for using the Prime 4 standalone.
The only thing to be aware of is if you're planning to record or stream, the record signal from the Prime 4 audio interface is really quiet.
Posted Tue 09 Feb 21 @ 12:17 pm
Thanks kindly.
Posted Tue 09 Feb 21 @ 7:26 pm
