Topic: connecting up 4 decks
hi
i want to use 4 decks 2 x gemini cdj650 and 2 x gemini mdj600 mixer is a numark m6
decks show and scroll the music but when i press play on decks 3 or 4 the sound comes through channel 1 or 2.
any help setting up is appreciated.
Posted Sat 30 Jan 21 @ 6:43 pm
In settings -> mapping you can force controller to work for a specific deck
You may also define a specific Audio config in a way to output to other channels
Routing can be done without any problem, but need to be done manually
note that for everything to work fully (after demo period) you have to get a pro license
any help on mapping as not sure where to look.
if all works i will get a pro licence....but want to make sure it will work first
sorry should have said i have only used vinyl in the past this laptop thing is all new to me...
these are settings
click the gear top right of the main screen
you'll find "mapping" and "audio" tabs on the left
"laptop thing is all new to me..." ... don't be afraid it may not be difficult
you'll find everything needed there:
https://virtualdj.com/manuals/virtualdj/settings.html
Sorted
many thanks......
now looking at pro licence
