While using Traktor I have very rarely needed to make beat grid adjustments, and I play a wide range of genres.
Now when I play reggae or anything earlier than 90s the songs beatgrid seems to be off beat alot.
Is there any known third party softwares for this or any other way to make auto beatgrid adjustments?
Would it be possible to import eg traktor-analyzed beatgrids?
Posted Fri 29 Jan 21 @ 7:34 pm
Go to first beat, and tap once.
That should sort it..
If you click the BPM value in Pro/Performance skin you will see a "Tap" button ..
Or you can map a keyboard button with the action : beat_tap
Posted Sat 30 Jan 21 @ 10:03 am
