Guys help needed asap.
i installed denon mk2 600 to test then deleted all drivers ect.
now my vdj still keeps trying to set it up and I can't get my ddjsx to work....keeps opening audio config to hardware denon how do I delete all denon
Posted Sun 27 Dec 20 @ 3:57 pm
is the denon still connected to the computer?
Posted Sun 27 Dec 20 @ 4:04 pm
No I've just deleted all drivers ect and re downloaded vdj.
I also removed the sound setting for denon in settings...
so now new vdj did not restore my normal setting for modified stuff I had
Posted Sun 27 Dec 20 @ 4:12 pm
So after clicking save my settings before deleting vdj to redownload it deleted my settings
Posted Sun 27 Dec 20 @ 4:45 pm
Some controllers works without drivers, and VirtualDJ auto detects connected controllers.
So if its still connected, it might show up..
Anyways, just go to sound settings, select the SX and all should be fine ;-)
Should even be a popup asking if you want to use the SX as the default sound at start up..
Btw, the DDJ-SX do need drivers and firmware update if available.
If you didnt do that, you need to do that first: https://virtualdj.com/manuals/hardware/pioneer/ddjsx/installation.html
Posted Sun 27 Dec 20 @ 4:53 pm
