I got a new pc for Christmas and will be transferring my music to an external drive to use on new pc. What external ssd drives would you suggest to make sure searching speed etc is fast ?
Trying to make sure I get the correct drive.
Thanks everyone
Thanks everyone
Posted Sat 26 Dec 20 @ 2:27 am
I´ve good experiene with Samsung drives.
For example T5, T7 or X5 series.
I just would not go for a "touch" version as here is a finger rpint protection inside that may require some kind of driver/software that could disturb VDJ.
But this is could/should/would, I just would skip it for prevention and have no pratical experience with this function.
Posted Sat 26 Dec 20 @ 10:51 am
Usb 3 or usb C?
Posted Sat 26 Dec 20 @ 11:11 pm
USB 3 is as well available in A/B format and not only in C.
If the laptop has the connector I would go in 2020 on the USB-C.
Just due to the fact that it is more future proof and has the more easy connector (plug in both directions).
Posted Sun 27 Dec 20 @ 1:01 pm
I've been using Samsung T5 drives for a while now and they're great. They come with USB A to C and C to C cables.
Posted Sun 27 Dec 20 @ 1:14 pm
WD My Passport Ultra been using for a couple years works great
this is mechanical not SSD
SSD is great if you are worried about a lot of vibrations also can be very durable :-)
Posted Sun 27 Dec 20 @ 2:14 pm
