Anybody else noticed this possible bug on loop out fades out as normal then volume increases at end of effect was ok until latest update.
set at 1bt length
mode step
mode param 50%
count 4
set at 1bt length
mode step
mode param 50%
count 4
Posted Wed 23 Dec 20 @ 11:21 pm
I haven't used it in a while but it has all sorts of issues, now I check.
step as you mentioned
fade, doesn't fade, actually comes in louder
lp well depends where in the track you call it, early it works, some places it just goes silent, other places it filters in not out
HP didn't check
*edit*
Actually think I stumbled into maybe the why, sampleRate, tracks with a 48kHz rate offer the problems I mentioned
44.1, seem ok but there is a little click when HP or LP to stop but on my rig this effect has serious problems with 48k
HP didn't check
*edit*
Posted Thu 24 Dec 20 @ 12:11 am
problem addressed with early access BUILD 6235 (2020-12-26)
seems fixed
seems fixed
Posted Tue 29 Dec 20 @ 1:12 pm
Thank you for your help
Posted Tue 19 Jan 21 @ 11:19 pm
