Hey everyone,
I'm experiencing major problems with my scratching on Virtual DJ. There seems to be a delay with my Jog Wheels. I've tried using both the DDJ 400 and DDJ 1000 controllers and the problems persists. I've attached a screenshot of my current Jog Wheels settings and it would be great to know if anyone else has had similar problems. Any help would be very much appreciated!!
It would also be useful to know what settings you use to scratch with.
Posted Thu 17 Dec 20 @ 11:25 am
You're not using Bluetooth headphones or speakers are you?
No you haven't :-)
Posted Thu 17 Dec 20 @ 11:34 am
Try set touchwheelBackspin to "no" in VirtualDJ setting options.
That will probably make the jogs feel a bit "tighter" ..
Posted Thu 24 Dec 20 @ 12:58 pm
Same here. Sx2 controller. Touch is perfect. Scratch is sluggish and delayed. Backspin setting is off and other settings related to scratch is standard. Sx2 controller internal settings is checked and standard. Controller tested on Traktor, Rekordbox and DJAY pro on same computer and works perfekt.
Posted Thu 24 Dec 20 @ 5:18 pm
