So far I've only found information on doing custom crossfader curves that effect ALL frequencies at once.
Is there a way to do the custom curve below with stock Virtual DJ? If there is, how do I do it? If not, what skin/plugin/mod/etc is available to do so? I'm wanting this done with no manual use of equipment/mouse/keyboard/touchscreen for each auto crossfade.
BASS: 0.0=[1.0,0.0]/0.46=[1.0,0.0]/0.49=[0.0,1.0]/1.0=[0.0,1.0]
MIDD: 0.0=[1.0,0.0]/0.5=[0.9,0.9]/1.0=[0.0,1.0]
TREB: 0.0=[1.0,0.0]/0.5=[0.9,0.9]/1.0=[0.0,1.0]
Posted Thu 19 Nov 20 @ 4:16 am
Do you mean customized curves on eq_crossfader_xxxx vdjscript ? If so currently it is not possible.
Posted Fri 20 Nov 20 @ 8:24 am
While not curves, perhaps you might be interested in the actions:
eq_crossfader_high
eq_crossfader_low
eq_crossfader_mid
That will crossfade by frequency between the decks.
Posted Fri 20 Nov 20 @ 11:41 am
