Is it possible in a near future the skin feature something like this ??
Posted Thu 12 Nov 20 @ 7:22 pm
Since VirtualDJ works with user made skins, almost "anything" is possible ;-)
Can check out available skins here:
https://virtualdj.com/plugins/?category=skins
Posted Thu 12 Nov 20 @ 7:29 pm
There's also Skin Builder by djdad that can be used to make your own skin exactly the way you like.
It runs as a skin itself, then you use the Skin Builder Extractor app to save the result as a finished skin.
Posted Thu 12 Nov 20 @ 7:58 pm
I like que default skin of VDJ just asking if is possible to and something like that to the default skin...
Posted Thu 12 Nov 20 @ 11:39 pm
