Hello guys, I am responsible for the technique of our registered association for dancesport. We are now digitizing our Dancemusik CDs and offering our members to play them by touchscreen with your software Virtual DJ. I started to adapt a skin for touchscreen and our special purposes. Now I am trying to get different songs organized in playlist to be played one by one with a timer of 90s.
Some explanation:
To train the final rounds in a competition and to get the stamina we play for standard dances a Waltz for 90s then a 15s pause, then a Tango for 90s and 15s pause, then Slow Fox for 90s with 15s pause, then Vienesse Waltz for 90s and 15s pause and then a Quickstep for 90s with 15s pause. After that it starts again with Waltz.
To automate this procedure I would like to assign a button with a script that do this and stops when the button is pressed again:
I have a solution for playing single playlists by automix and randomize the songs:
var_equal "Waltz" 0 ? off & set "Waltz" 1 & browser_gotofolder "C:\Users\Dancers\Documents\VirtualDJ\Playlists\Waltz.m3u" & playlist_load & playlist_randomize & automix ? nothing : automix : on & set "Waltz" 0 & automix ? automix & play_pause : nothing
This works well but I'm getting confused with 10 dances and I don't really know how to script the 90s play and the 15s pause.
I tried this:
set "Playlist" 0 & var_equal "TrainFinalRound" 0 ? off & set "TrainFinalRound" 1 & repeat 90000ms & cycle "Playlist" 2 & automix_skip & var_equal "Playlist" 1 ? browser_gotofolder "C:\Users\Dancers\Documents\VirtualDJ\Playlists\Waltz.m3u" & playlist_load & playlist_randomize & automix ? nothing : automix : browser_gotofolder "C:\Users\Dancers\Documents\VirtualDJ\Playlists\Tango.m3u" & playlist_load & playlist_randomize & automix ? nothing : automix : on & set "TrainFinalRound" 0 & automix ? automix & play_pause : nothing
But something is wrong with the button on/off state and it do not have a pause.
Do you have any hints?
Best Regards
Tobias
Some explanation:
I tried this:
Best Regards
Tobias
Posted Thu 22 Oct 20 @ 2:09 pm
Could use the Event Scheduler for this.
Might be easier ;-)
And you can save such scheduled events, so that you have multiple available, for later use etc
And can be started with buttons : eventscheduler_start "danceWorkout"
( to stop just call eventscheduler_start)
https://virtualdj.com/manuals/virtualdj/interface/topsection/appcontrols/eventscheduler.html
Might be easier ;-)
Posted Thu 22 Oct 20 @ 2:13 pm
Wow, thanks! I have not got a clue about the Event Scheduler but this helps a lot. Thank you very much! My honest regards, Tobias.
Posted Thu 22 Oct 20 @ 2:24 pm
