Hi,
im evaluating some sound enhancers because im playing a lot of old tracks.
It needs to be 64 bit (for VDJ 2021). It should enhance sub bass and it should have an exciter.
Ive found Nomad Factory Cosmos VST plugin. But, before i will buy, it i would like to ask you, do you use any other enhancer? Can you recommend some to me?
Thank you
Thank you
Posted Thu 08 Oct 20 @ 9:59 pm
I have used iZotop Ozone 9 in the recent past, but you must be careful with what elements you enable on your chain as it's easy to introduce extra latency.
One of the best mastering plug-ings I ever tried... Ain't cheap though!
Posted Thu 08 Oct 20 @ 11:33 pm
I miss breakawayDJ... Lol.. #IYKYK
Posted Fri 09 Oct 20 @ 2:55 am
Waves do one called Vitamin, that won't shock your wallet too much.
Posted Fri 09 Oct 20 @ 9:13 am
I sometimes use Neutron Elements because it has an exciter. I've picked up on a good deal around $29 and it's worth every penny.
Posted Fri 09 Oct 20 @ 10:16 am
Thank you all, i will take look to them.
Neutro Elements for $29... That was'nt a deal, it was a gift :c)
I wish i would get that for this price :c)
Posted Fri 09 Oct 20 @ 10:26 pm
