Topic: Pops/Clicks/High pitched glitching with DDJ RZX - Page: 2
Did you try both the 32-bit and 64-bit version of VDJ?
This is VDJ 2021 version with STEMS support which is why im upgrading the PC... As far as I know VDJ is now 64bit only from 2021 onwards.
That is correct, but the 2020 32-bit version without stems can still be downloaded as well:
https://virtualdj.com/download/build.html
Of course not as a final solution, but could be useful to see if this makes any difference.
It is indeed possible that it is due to a texture size misalignment, although it doesn't sound too likely with any modern gpu of the past 15 years (even integrated)
As suspected fitting a GTX 1650 to this machine has fixed the screen issue... so that was probably down to some render texture weirdness with the integrated gfx driver... However... VDJ is now telling me that this card doesn't support GPU acceleration? which im pretty sure it should do... just trying to install the drivers via Geforce Experience instead of whatever windows automatically picked up...
Couple of restart of VDJ and it picked up the graphics card and downloaded two absolutely massive dll's and now GPU maths acceleration works... it analyses a track in 2 seconds flat... Happy days :)
