I'm using CDJ2000 NXS2s via USB and they're occasionally causing audio dropouts (that time stretching sound).
I'm using WASAPI but not sure if/where I can get ASIO if that's what's causing it?
Also point out that this doesn't happen on any other type of deck 2000/2000Nexus and I've tried it in 2 different clubs with 2 different pairs of decks
It only happens with the NXS2's
Can anyone help?
Can anyone help?
Posted Thu 01 Oct 20 @ 4:58 pm
Probably you should install the ASIO drivers then.
You can get them from PioneerDJ website HERE
Posted Thu 01 Oct 20 @ 7:18 pm
