I recently upgraded to Windows 10 from Windows 7. I realized that at the same levels, the output using windows 10 is considerably lower. Please advise.
I use: Numark NS6II, VirtualDJ 8.2, Windows 10,
There is a new popup window during set up: Equalizer Controls, under advanced EQ Mode, which option do I choose.
Posted Fri 25 Sep 20 @ 7:09 pm
go into settings in windows 10 go into sound and make sure audio output is at 100% as checked mine and it was at 75%but not sure about the pop up the pop up window hope it helps
Posted Sat 26 Sep 20 @ 6:53 pm
