All automations related to the deck are off. Key, bpm, smart play are off. Master Tempo is enabled on both decks. When autobpm is enabled, is not matching the other deck's bpm at all. For example, I have a track that reads 117bpm, and when the other track is loaded, (119 bpm), it loads at 116bpm. So what gives? Went through the options page, disabled whatever was applicable, and still does the same thing. Any suggestions are more than welcome
Posted Fri 18 Sep 20 @ 10:28 pm
Good evening,
did you check the PitchRange in the option, see if it is 2.0 that can come from there.
The default values of vdj 6,8,10,12,20,25,33,50,100
I work with the value 33.0
or simultaneously click on the PitchRange display
Posted Fri 18 Sep 20 @ 10:56 pm
not sure If I'm understanding your issues correctly unless its a 'typo' but you can only have one deck set as the 'master'' as soon as you load a song onto another deck it should see the bpm of the master deck and automatically sync it to that
Posted Sat 19 Sep 20 @ 4:11 pm
not sure either....
but on load, display bpm do not always (rarely) match as explain in 1st post. It automatically sync only at play time
don't know really why, maybe some multiple bpm in master bpm deck are taken in consideration, not only the current one
Posted Sat 19 Sep 20 @ 4:25 pm
maybe this video by Klaus helps you out
https://youtu.be/eKQm6-kVcsU
or
https://youtu.be/lpY0uD5Dh4k
or
Posted Sat 19 Sep 20 @ 5:24 pm
Sorry but they are far outdated... 8.3, pitch,key and bpm features have changed in 2018 some auto* overrides settings changed with 2020 were fixed and now it's 2021 ^^
the concept still OK in some situations, depending on many recent settings added
Posted Sat 19 Sep 20 @ 5:44 pm
There is a newer one here:
Posted Sat 19 Sep 20 @ 6:40 pm
