Can Stems be made to compute on load but delete file after it is removed from deck? The files it creates are like over 20Mb almost 3 times the size of original Mp3? All I see is Create manually , Always create and only use precompute.
Posted Mon 10 Aug 20 @ 11:19 am
Create manually is what u want then. Track will be Stems-analyzed when loading, without creating any file in HD
Posted Mon 10 Aug 20 @ 11:22 am
If it's set to the original system of computing during load, then there is no file created. Everything's done on the fly, each time a track is loaded.
Posted Mon 10 Aug 20 @ 11:23 am
Ok thanks, so can precompute folders I use "in normal times" often and leave those I don't to manual.
Posted Mon 10 Aug 20 @ 11:27 am
there you have to be careful,
by right clicking on a title, do not click on precompute the stems, if you do
it will display a small blue icon in the audio column.
And will also create the vdjstems file in the MP3 location folder.
Posted Mon 10 Aug 20 @ 3:41 pm
