Hi all
I have just changed laptop and VDJ is working fine.
But I cab't cue via heaphones. I get the master output on the headphones
I have the following settings:
Master : Mixon 4 : Chanel 1 & 2
Headphones : Mixon 4 : Chanel 2 & 3
Any help apreciated
Any help apreciated
Posted Wed 05 Aug 20 @ 10:51 am
The Mixon 4 should be plug & play. When the popup appears, select the option to use the soundcard.
If you can't (or didn't) do that, click the Mixon 4 button in the audio config window.
If you can't (or didn't) do that, follow the setup guide https://virtualdj.com/manuals/hardware/reloop/mixon4.html
Posted Wed 05 Aug 20 @ 11:09 am
Also download and install the new ASIO driver for Mixon version 1.0.2 from https://www.reloop.com/downloadfinder
Reloop changed the driver recently and unfortunately the version number is included in the ASIO name as you can see in the Manual
Therefore, if the new driver is not installed, VDJ will use the WASAPI, which should be fine as long as the Channels are used properly (1,2 for Master and 3,4 for Headphones)
Posted Wed 05 Aug 20 @ 3:22 pm
That fixed it! Thanks.
Posted Wed 05 Aug 20 @ 3:31 pm
