how do i keep the highlighted (Focus is on) song in view after I've select grouping or any other tabs while i'm in the sideview or sidelist browser? Just as it does in the main browser. Thanks for any help.
Posted Wed 24 Jun 20 @ 8:03 pm
Maybe it's how the question is asked, but still, no one can help me with this?
Posted Thu 25 Jun 20 @ 9:48 am
you could try set
showHorizontalSideListto
yesand then map a key to
sidelist_addto save the music that is highlighted to the side list and by doing this and adjusting the "right" height its like you have "pinned" that song in the browser.
Posted Thu 25 Jun 20 @ 10:45 am
question is asked an understandable way...;)
but i'm affraid keeping/getting the selected track in visible area is not possible ^^ unless something changed recently
(even just changing skin layout, column sort, grouping moves to top or stay where it is, but don't follow the highlighted song)
Posted Thu 25 Jun 20 @ 11:13 am
Appreciate ithe response guys. I'm sure sooner or later there will be an update to correct this.
Posted Thu 25 Jun 20 @ 11:45 am
When you switch views (or scroll with your mouse) and the "highlighted" track gets out of view, you can bring it back by simply using the scroll knob on your controller (or arrow up/down on the browser when shortcuts are disabled)
By default, when you engage browser_scroll action, the browser will scroll automatically on the area of the focused/highlighted track
Posted Thu 25 Jun 20 @ 6:00 pm
Thank you phantom. With that in mind can you please offer a script that I can mapped to a key that would combine two actions? In my case it would be keep highlighted song in view and grouping.
Posted Thu 25 Jun 20 @ 11:53 pm
