Topic: VirtualDJ 2021 : Real-Time Stems separation - Page: 1
THE FUTURE OF DJING IS HERE NOW !
VirtualDJ 2021 uses advanced technology and the power of modern computers to revolutionize what DJs can do.
Introducing real-time stem separation on any track, making perfect live mashups and seamless transitions the new normal.
Like usual, the update to VirtualDJ 2021 is completely FREE.
Go to virtualdj.com/download to grab your copy today.
Enjoy !
Posted Thu 18 Jun 20 @ 6:35 pm
Please stop resetting the skin, padding and auto pitch / BPM setings every time there's an major update.
We know the features are there so stop forcing them.
hi where find stems?
where did you have website to buy?
thanks
No, it doesn't play stems. Just play a normal track, and use the new EQ to isolate the different parts.
Should I download it and install it to upgrade?
Is it going to overwrite the existing build already installed? Or will it be installed aside?
So I selected the EQ method when it asked and realize I want to change that now, is there a way to get to the picture with descriptions again? I think I found the settings but I as usual didn't read the description so want to see it again, or if someone can screenshot that and post it thanks
It's the little button to the right of the top EQ.
thanks
just play any audio file and it will create the stems automagically for you. all for free, nothing to buy.
yes, it's going to overwrite the 2020 version.
if you want to keep both in parallel, copy your virtualdj.exe from program files to virtualdj2020.exe, before doing the install.
system requirements?
There was indeed a small bug in the current release, that resets some settings when upgrading from 2020 to 2021.
It's been fixed now and a patch will be available soon.
Cool
Stephane Clavel wrote :
By Me is no Button there in the Default Skin?
skin Default
LIMOL wrote :
skin Default
By me is not this Button in Default Skin ...
can you show us a picture here
Have you checked that you're running VDJ 8.5 b5918?
Yes , Install over old Version.
Cant als find no Stem Pads or a new Vocal Color Fx.
Only the Options are new , and a Pair of Mapper Commands.
Waves are also not new I can see..
Here screenshots.
Or is there a diverence on 32 bit version?
Yes, although the build number is the same, the 32 bit version is named 2020 and 64 bit 2021. Seems they are different.
That's going to confuse people.
13%
