Hi folks, I currently use the American Audio VMS5.0 controller and I am using XLR Mic, now on this controller, the mic controls are on the front and consist of on/off, Gain, Treble, mid and Bass and thats it, is there any way to add effects even tho it seems to be XLR through controller to Speakers from what I can make out and not routing from laptop to VDJ.
Any help is appreciated, Thanks.
Posted Sat 30 May 20 @ 12:41 am
If your mic is routed through VDJ You may try dedicated pads "Mic FX"
Posted Sat 30 May 20 @ 12:53 am
Its not routed through VDJ, seems to route through controller direct to speakers
Posted Sat 30 May 20 @ 11:56 pm
