Hi guys, I've just booted up my laptop that's not been used for ages as I need to use it at a gig. As soon as I open VDJ it comes up the update VDJ message, which I select. It then shows the downloading 2020 version and once it has done that nothing happens? I am signed in with my account so it should know its legit.
Am I correct in thinking I can just download the program in full from here and re-install it? I'm not worried about the database on the laptop as I use a pocket drive anyway.
Thanks for any advice.
Paul
Paul
Posted Mon 27 Jan 20 @ 2:16 pm
Sure - just download latest version (32 or 64 bit if on windows), and install on top
If enough of it got installed the first time for the installer to notice it, simply click repair - if not then just install normally
Posted Mon 27 Jan 20 @ 3:37 pm
Perfect - thank you very much for the reply !
Posted Tue 28 Jan 20 @ 9:07 am
