Hi,
If you are using two different computers with different databases on them (i.e. some different tracks, track locations etc), is there a way to transfer individual track info between databases without transferring the whole database?
So I have prepared a track with multiple bpms on one computer and I want to transfer that info onto my second computer without going through the time consuming process of putting in all the BPM anchor points a second time..... is there any way of doing this?
Cheers
Cheers
Posted Mon 27 Jan 20 @ 1:49 pm
Easiest is to copy the file to an external drive from within vdj, this will copy the database info onto the drive as well.
Then copy it back on the other computer, and this should update the local database as well.
Posted Mon 27 Jan 20 @ 1:50 pm
Thanks Adion,
Brilliant - I thought there must be a way with VirtualDj!
Posted Mon 27 Jan 20 @ 2:22 pm
You could also network your two machines, if you know how to do that.
Posted Mon 27 Jan 20 @ 2:53 pm
Nope, that one's beyond my paygrade Locodog! :-D
Posted Mon 27 Jan 20 @ 4:57 pm
It's also likely that VirtualDJ will not find the remote database through the network, so it might not be updated that way.
Posted Mon 27 Jan 20 @ 5:02 pm
It saw mine when I was running 2 machines [a while back], but I always keep music on it's own partition.
Posted Mon 27 Jan 20 @ 7:29 pm
Just tried it out and it worked perfectly.
Thanks Adion
Thanks Adion
Posted Mon 27 Jan 20 @ 8:47 pm
