When I use virtual DJ on my MacBook Pro Retina 13"
and press the maximise button it goes fullscreen and to make it a bit smaller I press maximise button and the hole of virtual dj goes super small takes me 30 min to get the maximise button to open it normally.
but when I try it on my MacBook Pro 13" that's not a Retina it works 100% with no issues.
help?
help?
Posted Thu 16 Jan 20 @ 8:32 am
You can drag the bottom right edge to change the size of the window....
Posted Fri 17 Jan 20 @ 6:10 pm
Somrtimes when you tried some other skins with extra windows it may be the problem
in full screen mode resize is not possible
in windowed mode VDJ is using the wrong window size
in this case you may want to reset skinWindows setting - even it appears empty
Posted Fri 17 Jan 20 @ 6:23 pm
Hey there, i am having exactly the same issue with my mac book and cant find a fix. Did you manage to work anything okay?
Posted Sat 24 Oct 20 @ 9:35 pm
Drag bottom right corner to size it up again. (and this new size will also be remembered).
Alternatively, you can rename settings.xml in /documents/virtualdj/ to start fresh with default size
Posted Sat 24 Oct 20 @ 9:39 pm
one of the best solution i found not loosing the settings is:
double click the bottom right corner in a way to reset skin size and go back to windowed
else go fullscreen and doubleclick the right corner
auto resize prevent skin to go less half design width
for future ... map a key i.e.: home to "maximize +1"
Posted Sat 24 Oct 20 @ 11:45 pm
