All,
I currently do not have a subscription, but a single license for my current controller. If I were to purchase a new/upgraded controller, would I need to also purchase another license for that one? Or is it possible to remove my old controller and replace it with the new one? Trying to move up in the world, haha. Any help is greatly appreciated.
Posted Fri 20 Dec 19 @ 10:23 pm
You would need to purchase a new license for the new controller.
I would suggest upgrading to Pro. That way it doesn't matter how many times you update your controller, so long as its supported it will work and you'll not have to pay again.
Hope that helps.
Hope that helps.
Posted Fri 20 Dec 19 @ 10:25 pm
OK, gotcha. Thanks for the quick response. I will look into the upgrade to Pro, since I am already looking for my device upgrade as well. Also, would I still retain my license for the "old" controller, in the event my newer one takes a dump or I need a backup?
Posted Fri 20 Dec 19 @ 11:04 pm
Pro is absolute, you could use any controller, dvs, auxiliary controller, all 3 at once.
controller licence is bed and breakfast, pro licence is all inclusive.
Posted Fri 20 Dec 19 @ 11:34 pm
I meant if I picked up another "per-controller" license for the new one, would I also keep the license for the old one. Although I intend to pro it up, just wanted to know in case life decides to interrupt. Thanks again to all responders.
Posted Fri 20 Dec 19 @ 11:47 pm
Yeah you keep the old, but as I see your profile, you're LE . Last time i looked LE gives a 50% discount for pro, $150 for pro is a no brainer.
Posted Sat 21 Dec 19 @ 1:31 am
My license page says I have Home Plus, which was ok since I am only a couch DJ at home. But I would access to some of the other features, like mentioned previously (unlimited controllers, etc). I may, for the time being stay with a single home plus when I get my new controller and license and then just get the iDJ subscription as a place holder. Thanks for your time.
Posted Sat 21 Dec 19 @ 1:51 am
I purchased a numark mixtrack 3 with virtual DJ LE8 added, but i have since upgraded to a pioneer DDJ-RB, As i only used numark a handfull of times i am giving it to my mates kid for xmas, how do i go about giving him the licence as well, obviously he will open his own account but the controller & licence are already registered to me.
Posted Sun 22 Dec 19 @ 4:32 pm
