Topic: massive loss of audio effects
I use to use all the audio effects on my apc 80 . Each button was linked. I went tonight to record a set and realized most of the effects are gone. I tried to make a duplicate of my beat grid like we did in the old days and then set them each differently but virtual wouldn't see them. I had collected a ton of vst and none of them work now. any advice or thoughts ?
Posted Tue 12 Nov 19 @ 6:34 am
The copy trick won't work as beatgrid is an native fx [no dll to copy] that shouldn't matter though as you can map to each of the preset slots.
Here's the first two, further slots are +0.143 on slider 1 greater than the last one.
effect_show_gui 'beat grid' ? effect_active 'beat grid' ? effect_slider 'beat grid' 1 0 ? effect_active 'beat grid' & effect_show_gui 'beat grid' : effect_slider 'beat grid' 1 0 : effect_active 'beat grid' & effect_slider 'beat grid' 1 0 : effect_slider 'beat grid' 1 0 & effect_show_gui 'beat grid' & effect_active 'beat grid' ? nothing : effect_active 'beat grid'
effect_show_gui 'beat grid' ? effect_active 'beat grid' ? effect_slider 'beat grid' 1 0.143 ? effect_active 'beat grid' & effect_show_gui 'beat grid' : effect_slider 'beat grid' 1 0.143 : effect_active 'beat grid' & effect_slider 'beat grid' 1 0.143 : effect_slider 'beat grid' 1 0.143 & effect_show_gui 'beat grid' & effect_active 'beat grid' ? nothing : effect_active 'beat grid'
Sounds to me that you've switched to x64 version of vdj, now you could dl the x86 version
https://virtualdj.com/download/build.html
and stay in the past
or you could go looking for new x64 vsts
loco saves the day, looking to find 64 b vst.. great explanation as always.
NP, the beatgrid slots scripts could be stripped right down [as is it also open/closes the gui too], like you with v7 I did the copy hack workaround. The scripts above are the very first v8 script I wrote [and I might have got carried away] but it's super robust, I've used those scripts, unchanged, since v8 went public.
loco the change happened in 2020. In saying that Its been fantastic other wise. kudos to the designers. I just was trying to fill one of the 120 buttons i have linked to effects. Its all good. im taking a break from djing till new-years eve . That gives me a few months to work it all out .
