For some strange Reason My right volume control on virtual 8 is stuck on low aprox 22% I have to use my mouse to make volume adjustments and its very frustrating. Im Using the new mark IDJ3 for my controller. Suggestions Appreciated.
Posted Wed 02 Oct 19 @ 7:51 pm
Sounds like your fader has a short, if you're lucky it might be crud that compressed air might shift, but give the age of idj3 it's likely worn out. not rocket science to replace but finding parts can be problematic.
Posted Wed 02 Oct 19 @ 8:16 pm
This is solid advice. I might add, you can try to spray some tech/contact spray into it, while it is unplugged. But, be judicious with it. It can cause other issues if you're not careful.
Posted Wed 02 Oct 19 @ 8:25 pm
And if all else has failed, try some percussive maintenance [give it a clout] [the old Fonzerelli fix]
Posted Wed 02 Oct 19 @ 8:32 pm
