Gang. I updated to new version a few mins before starting a set. It's gone haywire. Every song I load in changes its pitch when I press play. Gone into settings and set it to the way I had it in last version but its still doing it it. Pitch shift is connected and moves channel two when I shift channel one. When I press play it bounces up or down real quick
HELP
HELP
Posted Sat 28 Sep 19 @ 10:23 pm
Turn off types of sync you dont want to use, in deck options (small dot next to cue button)
Posted Sat 28 Sep 19 @ 10:28 pm
You may have just saved my life
Posted Sat 28 Sep 19 @ 10:32 pm
Why is this new version even changing existing settings. skin, padding etc. It's as though Atomix want to force the new version on existing users.
Same as forcing the video skins on with the previous version change.
If people want the new functionality they will find it themselves.
Posted Sun 29 Sep 19 @ 1:02 am
