v8.4 b5308
Could someone tell me the name of the setting that controls whether the pitch (sound frequency) changes when I move the pitch slider up and down.
It used to be when I made the song faster, the frequency stayed the same. Now, when I make the song faster, the frequency/pitch becomes higher.
I don't know where to change that.
Thanks,
Doug
Thanks,
Doug
Posted Fri 27 Sep 19 @ 3:34 pm
Switch master tempo on (MT in the deck display). It's in the manual...
Posted Fri 27 Sep 19 @ 4:43 pm
Thanks! I'm using the new version and can't find it anywhere on the decks (the UI isn't the same as in the pictures). However, I was able to find it in the settings by name.
Posted Fri 27 Sep 19 @ 4:56 pm
Yes it is. The manual was updated for VDJ 2020 several days ago.
Posted Fri 27 Sep 19 @ 5:01 pm
Ok, I found this via Google: https://virtualdj.com/documents/Manuals/VirtualDJ8_User_Guide.pdf and it didn't look the same.
I guess I'm not looking at the right page.
nothing found in a search here: https://virtualdj.com/manuals/virtualdj/action/search.html?search=master+tempo
I'm sure it's in there somewhere though. I probably just don't know how to find it.
Posted Fri 27 Sep 19 @ 5:30 pm
Should be on by default.
If not you can both change in skin, and in settings.. (search for mastertempo in settings)
In skin, its at "MT" on pro/performance layouts.. At number 6
https://virtualdj.com/manuals/virtualdj/interface/decks/trackinfo.html
Posted Fri 27 Sep 19 @ 5:40 pm
Ok thanks! I must have clicked that one by accident or something.
Posted Fri 27 Sep 19 @ 5:58 pm
