Yesterday I began to notice this problem and I had to restart the virtualdj several times. Today, the first thing I tried when turning on the computer and it seems that the problem persists.
When configuring the assignment of my controller, selecting the code and pressing the right mouse button to select cut, the software freezes and I can only retrieve it at the end of the task in the task manager.
I don't remember that this happened before, nor did a new update appear. Yesterday I opened the 64-bit version and it was updated, but the problem happens to me with the 32-bit version.
note: this does not happen using ctrl + x
Posted Sat 31 Aug 19 @ 7:26 am
I would like to download a version earlier than 8.3.b5186 and see if it solves my problem, since sometimes I forget it.
I found 8.3.b4514 and it does not give me this problem, but it does not allow me to identify myself (it must be a pirated version), so I have returned to 8.3.b5186 and this continues with the problem
sometimes it also happens when you select copy
Posted Mon 02 Sep 19 @ 9:15 am
