I've noticed my jog wheels/platters aren't very responsive with the default settings even in vinyl mode. If I move the jog wheel a fair amount it doesn't do anything, but if I keep moving them then it finally goes forward. I feel it's way off compared to anything I've ever used. I'm going to try changing some of these settings. Does anyone have any tips for this?
Posted Thu 27 Jun 19 @ 10:14 pm
I guess it's not so bad and tuned that way since the platters are small. The outside platter doesn't move fluidly (kind of darts forward all of a sudden) unless I disable vinyl mode. I'll keep practicing until it feels more comfortable. I was comparing it to my CDJ and I know they're not the same.
Also, it's probably meant to be this way in case of loud subwoofer bass vibration causing the platter to move by itself.
Posted Fri 28 Jun 19 @ 9:47 am
