in 7 years no crashes ... .over past 6 weeks.... crashed (program just freezes and I have to restart) 8 times. The only thing I can think of is the UGREEN external sound card that I added around that time. I have a huge show coming up Saturday. I welcome suggestions. I'm still using VDJ 7.4 if that helps.
thank you in advance for any suggestions . sincerely desperate lol
Posted Fri 07 Jun 19 @ 3:36 am
Well yes bad drivers can crash VDJ as well as other softwares
Try to use more recent drivers if any or older
You may also want to use VDJ 2018 - which may or may not crash - but is more stable have more features as a "pro infinity" licence user youll have full access to everything
Posted Fri 07 Jun 19 @ 6:08 am
What, the tiny little USB thing that costs $10? I'm not surprised it causes crashes. Is your budget really that limited?
I mean, even for domestic/consumer use, that's bottom end - and you're using it for DJ work?
Seriously, you're out earning money from DJ work. Invest some of it back into decent equipment!
Posted Fri 07 Jun 19 @ 4:35 pm
I purchased this as a emergency device. I understand your comment and respect it. Would you care to make a recommendation, for an external sound card? I have never used one before.
Posted Fri 07 Jun 19 @ 4:39 pm
It would help if you explained why you need one.
Posted Fri 07 Jun 19 @ 4:42 pm
If it does not require you to install drivers (just a standard usb audio device) then it should be no problem.
It is possible that it's a problem with the combination of recent operating system, this sound card and virtual dj 7 though, so you may want to try vdj 8.
If you have a big gig coming up, making big changes is probably not a good idea though, so just do the gig on saturday the way you did it before you used this new sound card.
Posted Fri 07 Jun 19 @ 4:47 pm
First , thank you for your time and your experience. Groovindj has been so helpful. I may not need the external sound card. I always used the headphone jack, but was told that external card were usually much better than what was on board. I only purchased to use when I was experiencing a possible bad headphone jack. I have made progress , thanks to this room on installing the latest VDJ 8 (Thanks Groovindj) I feel much better !
Posted Fri 07 Jun 19 @ 5:48 pm
True if you spend a reasonable amount of money on one, but not if it's only $10 worth. :-)
Posted Fri 07 Jun 19 @ 6:10 pm
Agreed
Posted Mon 10 Jun 19 @ 6:30 am
would you approve of the Focusrite Scarlett 2i2g2 to use as a usb soundcard ?
Posted Wed 12 Jun 19 @ 3:41 am
I think you would need a 4 out audio device [unless you run in mono]
Posted Wed 12 Jun 19 @ 4:10 am
I have used this https://www.amazon.com/gp/product/B006Y2BP1Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 in the past; but have since changed to Yamaha mixers (https://www.amazon.com/Yamaha-MG10XU-10-Input-Stereo-Effects/dp/B00IBIVL42) which allows me to connect directly to it with USB. You do have to make sure you download the Steinberg drivers (https://www.steinberg.net/en/support/downloads_hardware/yamaha_steinberg_usb_driver.html) that go with it though and load them. DO not use the one drivers Windows auto loads.
Hope this helps... cheers.
Posted Wed 12 Jun 19 @ 10:46 am
