I have some videos that have an audio format in 5.1 surround which translates to 6 channels at 448 kbps. For the purposes of playing them with Virtual DJ would they sound better if I converted them to a 2 channel stereo format?
Posted Mon 03 Jun 19 @ 5:44 am
VirtualDJ will already do that conversion for you, so unless you want to convert it with specific settings it should be fine already.
Posted Mon 03 Jun 19 @ 6:02 am
If you were rippping the original source, then I may recomend you to do this using the stereo audio version of the material you have and check it vs 5.1. Sometimes the original source for stereo output may have a different audio mixing and may or may not sound better than if is in 5.1 (for Stereo reproduction). If the source is already in 5.1 and you may convert to 2 channels, is not necessary because VirtualDJ already do it internally as already pointed out.
Posted Mon 03 Jun 19 @ 11:34 pm
